[DesignModeler] Extend fluid volume 3D nozzle
Like Tree1Likes
  • 1 Post By attiquejavaid08
Old   June 10, 2015, 08:16
Default Extend fluid volume 3D nozzle
Jacopo
Engineer1 is on a distinguished road
Hi, I have a 3D nozzle (imported from a CAD) with BCs of pressure outlet, so I decided to extend the volume domain to avoid reverse flow at the outlet.
Since I am new in fluent, I am not very experienced with this practise..
What is the best way to do that? I mean, can I create it in designModeler or must I do it in my CAD software? should I do boolean operations on the two volumes before meshing? and where should I impose the boundary condition of pressure outlet?
Thanks in advance
Engineer1 is offline   Reply With Quote
Old   June 10, 2015, 09:50
Attique Javaid
attiquejavaid08 is on a distinguished road
Thanks in advance
As per my understanding...
if you can model 3D nozzle in DM, then go for it (no de-featuring issue, which usually arise for complex geometries imported from CAD softwares), otherwise create extended geometry in CAD. yes, you have to do boolean operation to add them. and boundary condition will be imposed at end face of extended portion.
regards
Engineer1 likes this.
attiquejavaid08 is offline   Reply With Quote
Old   June 10, 2015, 09:57
Jacopo
I receive the geometry from a cad model (IGES or STEP file). Then, following your answer, I create a big fluid volume (for example 1m long) in DM after the nozzle outlet and I "merge" it with the nozzle outlet with a boolean operation, right?
The outlet BC pressure is 1 bar (absolute pressure) at the nozzle outlet. If I impose the BC to the "fake" outlet (the 1m longer one), what pressure must I impose?
Thanks
There is no fluid volume in the project Giron FloEFD, FloWorks & FloTHERM 5 December 30, 2022 08:58
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
[DesignModeler] Creating Fluid Volume willis ANSYS Meshing & Geometry 4 February 24, 2012 00:15
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 01:45
define the fluid volume nessi benishti FLUENT 0 August 2, 2005 16:57
