[ICEM] Scripting/geometry naming
Old   July 24, 2015, 04:16
Default Scripting/geometry naming
Ralf Becker
RalfBecker is on a distinguished road
i often come across a problem regarding the naming and automatic renaming of geometrical entities.
I create, for example, a point "pnt.21"
[QUOTE]ic_point {} POINTS pnt.21 0,0,0[/CODE]
in the part named "POINTS" and reusing it subsequently for curve creation, the point is automatically renamed to a different name. Hence I can't refer to it for later geometry
commands, except the point is recreated with a known name.
Is there a way to avoid this behavior of ICEM? Or, how could I deal with automatic renaming in scripts?
Thank you in advance
Ralf
RalfBecker is offline   Reply With Quote
time step directories naming issue Andrea_85 OpenFOAM 3 April 3, 2014 08:38
[TGrid] Tgrid naming boundaries , zones natantyt ANSYS Meshing & Geometry 3 May 28, 2013 14:13
[DesignModeler] Recurring solids and automatic naming chh ANSYS Meshing & Geometry 1 March 20, 2012 22:25
Results file naming convention amtri OpenFOAM 8 September 7, 2010 08:54
File naming convention roncresswell OpenFOAM Installation 3 December 6, 2005 05:01
