[ICEM] ICEM in batch mode : determinant
Old   July 16, 2015, 10:15
Default ICEM in batch mode : determinant
baba@cfd is on a distinguished road
I'm trying to write a simple script in batch mode which calculates the Determinant min (mesh quality) of a mesh.
For the moment I tried:
ic_empty_tetin
ic_read_external C://[path]/readcgns.exe D:/users/toto/Desktop/test.cgns
ic_str_metric Determinant {1 2 3 4 5 6 7 8 9 10 11 12 13 14 15}
I launch this through the ICEM batch mode (C:/icemcfd -batch -script myscript.rpl)
But it doesn't work. In fact it is not doing anything.
I think it calculates the stuff but how can I ask him to print the results or to write it in a file?
I am thankful for any help!
baba@cfd is offline   Reply With Quote
Old   July 21, 2015, 04:40
No one can help me please ?
Old   July 23, 2015, 08:20
Sune Niemann
Sune is on a distinguished road
You can try this approach:
set diag [ic_str_metric Determinant {1 2 3 4 5 6 7 8 9 10 11 12 13 14 15}]
set d0 [lindex $diag 0]
set d1 [lindex $diag 1]
set d2 [lindex $diag 2]
set d3 [lindex $diag 3]
set d4 [lindex $diag 4]
set d5 [lindex $diag 5]
if $d0 {
mess "Determinant:\n   Min = $d3\n   Max = $d4\n   Mean = [expr $d5 / ($d0 + 0.0)"
} else {
mess "Error! Domain most likely incorrectly defined"
Sune is offline   Reply With Quote
Old   July 27, 2015, 04:51
Thanks a lot for your help. It works well !!
Is there any option to select all the domains in my mesh for the calculation of the determinant instead of writing {1 2 3 4 5 6 7 8 9 10 11 12 13 14 15} ?
Old   July 27, 2015, 06:09
Sune Niemann
The ICEM Programmer's Guide gives little help for this function:
ic_str_metric type domains
I guess the s in domains indicates that it can take a list of domains.
You can build a list of all domains like this:
set doms ""
foreach dom [ic_str_list_entities domain] {
    lappend doms $dom
/Sune
Old   July 27, 2015, 07:24
In fact it works just with the command : ic_str_list_entities domain.
It builds the list I wanted.
Thank you Sune !
batch mode, determinant, icem 15.0
[ICEM] icem cfd batch mode srobin11 ANSYS Meshing & Geometry 20 August 2, 2020 18:40
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 07:18
[ICEM] ICEM CFD error when running in batch mode bgp723 ANSYS Meshing & Geometry 0 August 14, 2014 13:45
Batch mode ICEM CFD parametrization problem sportsfun ANSYS 0 December 19, 2012 14:20
