[ICEM] sequential node numbering in meshes
Like Tree2Likes
  • 1 Post By joxen
  • 1 Post By FJSJ
Old   July 30, 2015, 20:56
Default sequential node numbering in meshes
Mirunalini
mirukpt is on a distinguished road
Some of the meshes generated by ICEM do not have sequential node numbering. For example, in one of my nastran files (see attached), the node numbers are continuous upto 11 and then jump to 15. Is there a way to constrain the node numbers to be continuous while meshing in ICEM?
https://www.dropbox.com/s/97rgvhvgo0...oud25.nas?dl=0
Thanks
Mirunalini
mirukpt is offline   Reply With Quote
Old   September 29, 2015, 09:40
Joakim
joxen is on a distinguished road
Thanks
Mirunalini
Hi Mirunalini,
I have the same problem but import the geometry as .prt file from NX. Did you find any solution how to control the node numbers?
An other way for me to solve it to use
[CODE]
ic_hex_select_nodes 1 all m FLUID node_numbers
[\CODE] which returns all the node numbers that are connected to the part "FLUID".
An other form of this function is to locate the node in a specific point, coordinate, instead of returning all nodes. The function looks like this from the programmers manual
[CODE]
ic_hex_select_nodes num method index_range m parts
[\CODE]
and should in my case be:
[CODE]
ic_hex_select_nodes 1 inpoly {369.13875 211.52306 -1.1669954e-10} m FLUID node_numbers
[\CODE]
However this doesn't work, I'll get the error "Error: Error reading polygon coords"
Do you know how to solve this? Or control the numbers of the nodes?
Thank's for your assistance!
// Joakim
ramesh.naidu likes this.
joxen is offline   Reply With Quote
Old   July 30, 2017, 04:34
Javi
FJSJ is on a distinguished road
Hi friends,
I am trying to answer the same question of this thread's title. Could anyone help to understand blocking vertex numbering? It seems doesn't have any sequential rule.
Thank you in advance.
FJSJ is offline   Reply With Quote
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 09:46
Node numbering at interface in MeTiS. mehul FLUENT 0 December 19, 2006 10:22
