August 12, 2015, 06:46 |
simple 3D pipe mesh?
Rep Power: 16 |
I attempt to draw mesh for a 3D pipe with known number of meshes at inlet , outlet and along pipe length, the problem I able to set the number of mesh at inlet and outlet by using insert sizing>edge sizing and set the number of divisions to 10 meshes but with length i cannot find the edge along length to set the number of nodes as 1200? how I can set pipe length to this mesh number? any help is appreciated?
mariam |
August 12, 2015, 20:13 |
Rep Power: 14 |
Hi mariam.sara,
Easiest way to do it is by giving Body sizing, Choose (element size = Length of pipe /number of nodes) and then Give Behavior> Hard Cheers KAPI |
August 13, 2015, 04:14 |
Rep Power: 16 |
Thanks Kapi for the reply. I want to ask with applying your suggestion with setting the element size from the relation you mentioned using body sizing How can I ensure that the mesh distributed as 10 nodes at edge inlet and 10 at outlet and 1200 along pipe length?
Thanks Mariam |
August 13, 2015, 18:21 |
Rep Power: 14 |
Use Body Sizing as I explained before and then use "Edge sizing" at Inlet and outlet. Make sure you use Behavior"HARD" so that it only makes 10 nodes at inlet and outlet.
Cheers KAPI |
[GAMBIT] 3D Two pipe T-shape junction mesh | Jing | ANSYS Meshing & Geometry | 8 | April 26, 2013 12:27 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Grid Independence problem for simple pipe geometry | chanchala | FLUENT | 13 | November 20, 2003 08:24 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
