[ANSYS Meshing] Problem UDF for sinusoidal wall motion - FLUENT
Old   August 21, 2015, 14:46
Default Problem UDF for sinusoidal wall motion - FLUENT
avd28 is on a distinguished road
Hi all,
I'm trying to simulate a biological fluid flow which requires the use of pulsatile sinusoidal wall motion of the mesh. I have the UDF compiled and running. However there is a problem.
Each node is supposed to deform with the equation of the form Asin(wt) where t is the current time.
However, when the time step size is decreased from say 0.1 secs to 0.01 secs, the mesh amplitude unaccountably increases, for the same number of iterations. This of course results in formation of negative volumes in the mesh and the simulation crashes.
I have attached the udf file and will provide a dropbox link to the case file. In order to view the problem, simply simulate with a time step size of 0.01 as compared to 0.1 secs.
https://www.dropbox.com/s/pjdkjink6t...test1.cas?dl=0
avd28 is offline   Reply With Quote
dynamic mesh, dynamic meshing, meshing, udf, udf and programming
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
Fluent UDF c source file problem (Linux) jayilosa Fluent UDF and Scheme Programming 1 November 21, 2011 08:25
Wall function problem in Fluent mefpz FLUENT 1 October 10, 2007 13:43
