[GAMBIT] 3D Airfoil (wing) meshing
Old   September 15, 2015, 04:28
Exclamation 3D Airfoil (wing) meshing
Athos1387 is on a distinguished road
I'm trying to mesh a 3d airfoil (it's not exactly a wing) but it doesn't end well. after creating the model in 2d, I swept it and a 3d model was created. the 2d meshing is done well. I did it as told in the link below.
https://confluence.cornell.edu/displ...irfoil-+Step+2
the volume mesh of the 2 cubes in the left was done without any problems but the area around the airfoil itself can not be done. if I choose no scheme and spacing it shows the error in the image below.
it says I have to check the skewness which I did and there was no problem when meshing the faces. about the sizes, I did it with smaller and larger size too, but didn't worh either way.
I also triedmeshing with various schemes which gave different errors.
Help plese!!!
Athos1387 is offline   Reply With Quote
Old   September 15, 2015, 05:26
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
can you zoom on your airfoil
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   September 15, 2015, 06:53
yes, ofcourse. here are 2 pictures that I had already. if you need a picture with more zooming in or from a different view, tell me.
and thank you.
Old   September 15, 2015, 07:18
-mAx-'s Avatar
Maxime Perelli
can you provide the dbs file on a share server
Old   September 15, 2015, 07:42
here's the link for the uploaded file.
https://mega.nz/#!M45kjSBQ!ThFgUHWCj...qZUpzxS3Ww4m_o
it's a .RAR file with all the gambit files included. and the airfoil is a NACA0021 in case you need to know.
thanks.
Old   September 30, 2015, 07:42
found the problem. have to do the meshing with cooper but it doesn't work with 2 faces connecting to each other with one edge. so the trailing edge should have a small gap and the two half circles of boundary must be connected with two edges that have formed the trailing edge.
now another problem has risen. no matter how I change the interval size for volume mesh, nothing changes. I want to make smaller mesh elements. can anyone help please?!!!
Old   October 5, 2015, 00:56
-mAx-'s Avatar
Maxime Perelli
If you are working with cooper, and all your edges are already meshed, then the element size of your volume won't affect the real size element.
Other possibility: you have set a size function
Old   October 5, 2015, 07:47
I haven't meshed all the edges. the edges between the main faces and the ones that were sweeped are not meshed. also even if I don't aply the scheme, no matter how much I change the spacing, the element size and amount does not change.
I actually don't know what the size function is.
Old   October 5, 2015, 08:04
-mAx-'s Avatar
Maxime Perelli
upload your file on a share server (zip format please)
Old   October 6, 2015, 10:46
here's the link of the uploaded file.
https://mega.nz/#!w9RQyTSJ!pykMwoZvm...kJcZEwxHGKd2Sc
thanks.
Old   October 7, 2015, 04:15
-mAx-'s Avatar
Maxime Perelli
Look at your faces 11 15 16 18 & 19
Old   October 9, 2015, 06:11
Sorry but what do you mean by looking at those faces? what do I do with them?
Old   October 9, 2015, 06:24
-mAx-'s Avatar
Maxime Perelli
If you check those faces, you will see that they are still meshed.
Then the mesh size in x-direction is fixed (because of those faces)
Old   October 9, 2015, 13:47
Oh, I know that. I can already change mesh in x and y directions. I want to change the mesh in the z direction. but it doesn't allow me to do it.
Old   October 12, 2015, 01:25
-mAx-'s Avatar
Maxime Perelli
then you need to delete the mesh of your source faces (13;20;Rect1, Circ and so on..)
Old   October 13, 2015, 07:25
But I want to keep those face meshes as they are. if I delete them, the program will mesh them with a default mesh, won't it?
Old   October 13, 2015, 07:44
-mAx-'s Avatar
Maxime Perelli
wait I mixed x and z direction.
http://www.cfd-online.com/Forums/ans...tml#post567293 post #13
I was talking about z-direction
So if you delete mesh on faces 11 15 16 18 & 19 , then you will be able to refine your volume mesh in z-direction
Old   October 13, 2015, 08:26
Thanks, I'll try and let you know the results.
LATER:
Thanks a lot. you've really saved me!
airfoil, airfoil 3d, mesh 3d, volume mesh, volume meshing
[ICEM] Meshing a wing with a wind gallery crostolo ANSYS Meshing & Geometry 0 July 25, 2013 13:13
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
[snappyHexMesh] Meshing 3D wing (hydrofoil) fails klausb OpenFOAM Meshing & Mesh Conversion 0 December 28, 2011 14:26
[ANSYS Meshing] Icem 2d meshing for multi-element airfoil tetsuya ANSYS Meshing & Geometry 0 November 10, 2011 05:19
[GAMBIT] Problematic meshing of an inverted airfoil snkutta ANSYS Meshing & Geometry 2 October 11, 2011 13:23
