[ICEM] how to force hexa mesh to stick to surface (i.e. make edge nodes follow surface)?
Old   October 16, 2015, 15:04
Default how to force hexa mesh to stick to surface (i.e. make edge nodes follow surface)?
David
dave13 is on a distinguished road
Hi everyone,
I am having troubles fixing my hexa mesh to stick to the symmetry plane surface (see pictures). The problem arises when I replace the circular backwardfacing step geometry with a slope and it results in this hole in the mesh on both sides.
Any suggestions on how to fix this? Is it a blocking problem? Or will I have to try to set up a hybrid mesh with a tetra part for the slope?
Unfortunately I couldn't find any help in tutorials or other threads. I also checked that the blocks are well associated at these edges.
Any help is much appreciated! I can also provide files when needed.
Thank you,
Dave
dave13 is offline   Reply With Quote
Old   October 19, 2015, 05:28
Antanas is on a distinguished road
Originally Posted by dave13 View Post
Hi everyone,
Thank you,
Dave
Check associations
Antanas is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
To make sure nodes on surface Twiti CFX 0 December 23, 2004 20:06
