[ANSYS Meshing] Leaving solid part without mesh?
Like Tree1Likes
  • 1 Post By Antanas
Old   October 21, 2015, 15:20
Default Leaving solid part without mesh?
mariam.sara is on a distinguished road
Hello I have a fluid pass over solid thin wall with known thickness. I need just mesh the fluid region as shown in picture? is that possible in meshing program? if possible how i can do it?
mariam
mariam.sara is offline   Reply With Quote
Old   October 21, 2015, 22:05
Antanas is on a distinguished road
mariam
You need to create geometry for fluid region and mesh it. Isn't it obvious?
Antanas is offline   Reply With Quote
Old   October 22, 2015, 03:11
I think you not understand me. Actually I want draw two volumes one for solid and other for water I just want mesh fluid part and leave solid part without mesh (see last pict)? How i can do that?
mariam
Old   October 22, 2015, 04:47
mariam
Supress unwanted part
Old   October 22, 2015, 04:50
I attempt suppress the solid part then create mesh for fluid part only but the problem in Fluent just the fluid part appear? i want both parts appear in fluent? how to do that?
Old   October 22, 2015, 07:32
For what? Fluent, CFX and other codes operate with mesh, but not geometry.
Old   October 23, 2015, 07:13
Actually the picture i sent exist in ANSYS FLUENT 13 help files exactly in fluent_13.0_lecture07-heat-transfer file please refer page 8 & 9 to check this issue?? how they mentioned that its possible to leave solid part without mesh in Help files if not applicable in FLUENT?
Old   October 23, 2015, 09:18
You didn't understand. Solid region is not geometrically modelled and not meshed in that case. You specify wall material and thickness. Solver solves 1D Fourier's Law for heat transfer in normal direction.
Far likes this.
Old   October 23, 2015, 11:51
You mean wall boundary not material because you mention solid will not be modeled just fluid region will drawn?
Old   October 23, 2015, 14:06
Edit properties of fluid domain boundaries (walls) and you'll see material and thickness settings there.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] extrude surface mesh for solid wall Daniel_Khazaei ANSYS Meshing & Geometry 13 May 29, 2014 09:25
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
