[ICEM] Prism layer not completely forming at intersection
Old   October 26, 2015, 11:12
Default Prism layer not completely forming at intersection
Ontario
CCHunter is on a distinguished road
Hi
I am trying to mesh a prism layer around a cylinder that is going to have a jet blowing air onto it. There are two symmetry planes along the z-axis cutting through the cylinder on either side. One of the planes is also cutting through the jet.
When trying to make a prism layer around the cylinder in some cases it works fine and no pyramids form, in other cases (when the geometry is modified slightly for different jet spacing) pyramids form and the prism layer seems to fail at certain areas where the cylinder meets the symmetry plane.
The geometry can be seen here:
The poor quality elements are located here:
A close up of the prism layer not completely forming near the cylinder-symmetry intersection here:
There's only a few elements (~20) I'm just frustrated as to why this is happening and can't seem to figure out how to correct the issue. I am creating the prism layers (5) on an octree mesh, smoothing, then transitioning to a delaunay and smoothing again as the initial setup. Turning on auto reduction and turning off refine prism boundary and stop columns doesn't seem to help. I tried generating one layer and splitting it but the same issue happened.
CCHunter is offline   Reply With Quote
Old   October 27, 2015, 13:09
Ontario
bumping for visibility
Prism Layer (Boundary Layer) Thickness Peter-27 STAR-CCM+ 12 March 27, 2022 12:25
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 07:48
[ICEM] Holes in the prism layer Airon ANSYS Meshing & Geometry 3 September 12, 2013 06:08
Trimmer & prism layer peresah STAR-CCM+ 6 October 6, 2009 14:39
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
