[DesignModeler] How to plot two 2D tubes on over other in DM? |
December 4, 2015, 14:50 |
Rep Power: 16 |
Hello I attempt to draw a 2D geometry consists from two tubes one above the other the above tube there is a cold water flow through it and the bottom a hot oil flow through it. I start the plot with drawing two different sketches then draws two surfaces using add material option! the problem DesginModeler was combines the two tubes into one sketch (see attached photo please) i want two sketches?
any idea please?? mariam |
December 5, 2015, 13:23 |
#2 | |
Rep Power: 16 |
I hope somebody answer me??
December 6, 2015, 17:44 |
Rep Power: 14 |
Freeze the first sketch then draw second?
December 7, 2015, 02:52 |
Rep Power: 13 |
Or maybe try selecting the plane again for the next sketch and start drawing.
HLL Riemann Shock Tube Matlab Problem | Luke F | Main CFD Forum | 2 | May 20, 2016 02:10 |
[swak4Foam] Foam warnings - related to swak4Foam | Salam-H | OpenFOAM Community Contributions | 20 | August 2, 2015 15:40 |
Plot swirl number along length of a tube | Pacca | CFX | 6 | October 27, 2014 14:42 |
[OpenFOAM] Tube filter in Paraview | werweisswas | ParaView | 0 | December 10, 2012 06:18 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
