[ICEM] Faulty surface interpretation (unsolved) |
December 1, 2015, 10:13 |
Dave M.
Rep Power: 11 |
Hello everybody,
I have a problem, I hope you might have some useful hints for me.
Thank you in advance for your help - I hope anybody has had this kind of failure before (which I suggest) and has some solution. Best regards, Dave |
September 24, 2018, 13:37 |
Maharashtra
Rep Power: 8 |
Facing the same issue.
September 24, 2018, 18:18 |
Gert-Jan
Rep Power: 27 |
- Set Topology and triangulation tolerances tighter.
- Don't be mislead by the spiky edges and surfaces. This can be a matter of visualisation. Use your RMB on surfaces and select "Full" to get a tighter representation. - If you create a surface from 4 edges, you must be sure these form a closed loop. If not, then you will find a large surface, as given in the figure by Dave M. |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
