[ICEM] Best approach to blocking and meshing a twisted blade with a clearance gap?
Old   December 25, 2015, 11:51
Default Best approach to blocking and meshing a twisted blade with a clearance gap?
jack sparrow
supersweet is on a distinguished road
What is the best approach to blocking and meshing a twisted blade with a clearance gap in ICEM? A semi-structured grid works fine, but I would like to try and create a structured grid with hex elements.
Thanks.
supersweet is offline   Reply With Quote
Old   December 29, 2015, 14:07
shereez234's Avatar
MS
shereez234 is on a distinguished road
I think I know what you are talking about. If you post a picture of your geometry I might be able to help you a bit more.
Regards
Shereez
shereez234 is offline   Reply With Quote
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator Crank-Shaft ANSYS Meshing & Geometry 5 January 17, 2016 23:29
[ICEM] turbine blade meshing sk0pa ANSYS Meshing & Geometry 21 September 10, 2015 07:06
[ANSYS Meshing] Blade tip blocking Bollonga ANSYS Meshing & Geometry 108 November 6, 2013 13:59
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp Crank-Shaft ANSYS Meshing & Geometry 0 January 11, 2013 05:48
[ICEM] Hexa meshing blocking problem fergal ANSYS Meshing & Geometry 0 June 28, 2011 10:01
