[ANSYS Meshing] Howto sweep non-sweepable Bodies?
Old   January 21, 2016, 06:01
Default Howto sweep non-sweepable Bodies?
baxter85 is on a distinguished road
Hi Community,
my test model has a cylinder inside a cube. A third body covers the other two. (i attached geometry file).
Is there a way to mesh the the thin cover with the same mesh as the cylinder and cube are meshed? Sweepable bodies cant be used on the cover body ... is there way to sweep the cover body with one divison and the same base mesh the cylinder and cube have?
Hopefully somebody reads this and has a solution.
mesh.jpgetry file)
baxter85 is offline   Reply With Quote
Old   January 22, 2016, 00:57
hwet is on a distinguished road
For sweeping the target faces and bodies throughout the mesh should be consistent. For example in your case if you make a slice in the thin body with is a cylinder as the cylinder in the bottom part then you will be able to sweep mesh it.
This will not affect you simulation since even if you end up having multiple faces on a side which initially had one face you can name them all as a wall, inlet, outlet by multiselecting them and then in the cfd solver apply the boundary condition. hope i make sense. also for a cfd case dont forget to change the body type to fluid, can be solid if it is a mechanical case. just saying... since i noticed it in the pictures.
hwet is offline   Reply With Quote
Old   January 25, 2016, 05:43
hi hwet,
thx for the fast help. based on your hints i extruded the cylinder into the cover and than cut the bodies (see attached pictures).
The mesh now looks like i wanted. So it works fo this.
But i'm still looking for another way ... if i have more (many more) bodies like the cylinder i have to cut or slice each of them with the top layer.
kind regards, baxter
Old   January 25, 2016, 19:48
There is something terribly wrong with the mesh you have made.
Old   January 30, 2018, 06:31
Exclamation How to make this geometry fully sweepable
et.one is on a distinguished road
I am trying to make this body sweepable ( https://ibb.co/cRJC8m )
What I do is:
- slicing the two lateral cylinders --> which become sweepable
- slicing the bottom part, i.e. restriction + bottom cylinder --> which become sweepable
- slicing the hemisphere and the centrale part separately BUT they don't become sweepable in any way.
Any help would be much appreciated
et.one is offline   Reply With Quote
[ANSYS Meshing] Non Sweepable bodies b.shuvayan ANSYS Meshing & Geometry 22 February 1, 2018 06:28
[ANSYS Meshing] Sweep mesh results in extreme aspect ratio Highflower ANSYS Meshing & Geometry 4 January 12, 2016 16:40
[DesignModeler] [ANSYS Geometry] Error: Operation would result in non-manifold bodies -roberto ANSYS Meshing & Geometry 0 April 10, 2015 06:33
[ANSYS Meshing] Inlet Pump - Creation of sweepable bodies DarkRudy ANSYS Meshing & Geometry 5 January 28, 2013 07:58
[ANSYS Meshing] sweepable bodies & meshing sandy_1982 ANSYS Meshing & Geometry 6 November 1, 2012 08:04
