[DesignModeler] medelling a moving wall
Old   February 3, 2016, 07:57
Default Modelling a moving wall
Rikard
rikfr986 is on a distinguished road
Hi, I want to modell a piston that is pushed out of a cylinder, see attached picture, using design modeller and ansys meshing for CFX. My problem is how to model the walls around the piston since there will be a "wall-wall interface" that will turn into a wall-fluid interface. How can I tell the solver that there is a wall at the dotted red lines even if it is outside of my fluid domain at first?
Do I have to model the piston as a solid and mesh it as well? Have looked at the immersed solid option but what I can read it doesn't work for multiphase which I will use later. I have a moving mesh more or less working exept for this wall problem.
Hope it was understandable and that someone can guide me in right direction!
Last edited by rikfr986; February 4, 2016 at 10:05. Reason: wrong spelling in title
rikfr986 is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
How to make boundary layer mesh moving with wall wayne FLUENT 3 June 11, 2008 23:23
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
moving wall and fluid soody FLUENT 3 September 20, 2004 01:37
