[ICEM] Hole in the Mesh
Old   February 5, 2016, 12:34
Default Hole in the Mesh
Abhimanyu
iam_thedoctor is on a distinguished road
Im relatively new to the field and cant get around this problem.
Im trying to mesh a simple 3D geometry( a large cuboid) inside which are a cylinder and cuboid IN CONTACT.
I meshed it using tet once(octree then delauney) and had no problems but I later realized that i needed to define material points inside the inner cuboid and cylinder( they are to be simulated as different materials and hence have different properties),
Now when i defined these material points on these surfaces and tried meshing again, it gives an error telling me there is a hole, while there isnt one - the geometry checks out.
Ive tried playing around with the geometry and to no avail, even when im able to output a mesh, it wont recognize the two different materials that are in contact.
P.S as a side note, is it so that ONLY the volume meshed can be assigned a material?
for eg if ive to simulate flow over a hollow cylinder which sits on a cuboid - the mesh will obviously be around the solids and not inside the volume of the solids ; so how do i assign materials( say aluminium to cylinder and wood to the cuboid) ?
iam_thedoctor is offline   Reply With Quote
geometry, hole, material points, tet mesh, topology
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[ICEM] ICEM CFD Cooling Hole Hybrid Mesh RealENG22 ANSYS Meshing & Geometry 1 November 22, 2013 22:27
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
