[ANSYS Meshing] Meshing a cuboid with hex
Old   February 25, 2016, 09:26
Question Meshing a cuboid with hex
HAOWU
haow is on a distinguished road
Hi, everyone
I am using ANSYS Meshing module to mesh a cuboid fluid domain with hex cells. In order to use different cell sizes at different places, the body is divided into several smaller cuboids.
My idea comes from a thread '3D Multiblock Structured Hexahedral Mesh' in this forum:
edge sizing (control the bias factor along the edge)- mapped face sizing - multizone -generate mesh.
But I found the sizing control before generating the mesh did not work sometimes. Could anyone explain the true procedure to doing this?
Thanks very much,
Hao
haow is offline   Reply With Quote
Old   February 25, 2016, 21:18
hwet is on a distinguished road
where is the error when the sizing control did not work?
hwet is offline   Reply With Quote
Old   February 26, 2016, 07:48
HAOWU
Hi, I just tried on the options for Multizone. It seemed to be worked out after I chose 'uniform' instead of 'program controled' under 'surface mesh method'.
Like this:
Old   February 28, 2016, 17:27
noticed you have multiple bodies make sure to join them into one part, or you will not have conformal meshing
Old   February 29, 2016, 09:01
HAOWU
Yes. Thanks for your attention.
[blockMesh] --> FOAM FATAL ERROR: Trying to specify a boundary face A.A. OpenFOAM Meshing & Mesh Conversion 41 June 26, 2020 07:06
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[Other] mergeMatchPairs with arcs vainilreb OpenFOAM Meshing & Mesh Conversion 1 August 5, 2013 08:11
[blockMesh] apparently the mesh doesn't want to be created in one direction Maxime Thomas OpenFOAM Meshing & Mesh Conversion 1 August 18, 2012 06:05
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
