[ICEM] Poor quality Hexa mesh in ICEM-CFD but accurate solution |
February 24, 2016, 06:05 |
Suraj Kashyap
Rep Power: 10 |
I am modelling the volute of a centrifugal pump in ICEM-CFD. Upon running a quality check (determinant 3x3x3), I get some elements which have a quality of less than 0. I have tried a lot, but I cannot fix these elements without messing up others elsewhere. However, these poor quality elements are just 29 in number out of a total of ~459000 in the entire model (~0.02%). When I run the model in CFX solver, I do not get any error messages, and the output also matches experimental values quite fine. Is it that I am missing something here? Is it possible to have a few elements of poor quality and still have a good solution? I would have gone forward satisfied with the results but this is for my Undergrad thesis, so I do not wish to take the risk. If anybody can take a look at the model and help me fix these last few elements, it would be great! Thanks * I am unable to attach the .zip file here as it exceeds the size limit, but if anybody is willing to take a look, I can mail it to them. Update : I do get error for negative volumes in CFX Solver when I push up the refinement and the number of elements goes up to ~3000000.
And if thou gaze long into an abyss, the abyss will also gaze into thee. Last edited by surajkashyap; February 24, 2016 at 07:58. |
February 25, 2016, 22:57 |
Ghazlani M. Ali
Rep Power: 29 |
Refinement make cells smaller. And from my experience this always gives negative volumes. Even in icem CFD. What is the problem ?? Having bad quality does not always implies bad result. Those elements are not of an interests for the flow sometimes. Scalars may be of a bad value bad overall flow can be good.
February 26, 2016, 01:49 |
#3 | |
Suraj Kashyap
Rep Power: 10 |
As a follow-up question, would having a bad mesh compromise the credibility of my work for purposes such as publishing papers or participation in conferences, even if I validate my work with experimental values? Apologies if my questions sound very inexperienced.
And if thou gaze long into an abyss, the abyss will also gaze into thee. |
February 26, 2016, 11:09 |
You should go for the quality > 0.3 and angle > 18. Yes poor quality means poor results and means no publication. Improve your mesh. This is the most difficult case for ICEM CFD Hexa.
See Simon's presentation for handling same geometry in 2d. |
centrifugal pump, hexa meshing, icem, mesh quality, volute |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[ICEM] Hybrid mesh hexa and tetra on ICEM | PeterDaniel | ANSYS Meshing & Geometry | 0 | October 22, 2013 12:22 |
Solution on hexa mesh vs solution on tetra mesh | Chander | CFX | 2 | December 10, 2011 09:35 |
Boddy fitted Hexcore Mesh in ICEM Cfd | Mitch | CFX | 0 | December 29, 2008 06:07 |
Hexa smoothing (ICEM CFD 10.0) | CFDworker | CFX | 3 | November 2, 2005 10:23 |
