March 15, 2016, 01:29 |
Problem in geometry meshing
Kushal
Rep Power: 10 |
Hi guys,
I am trying to mesh geometry of pressure swirl atomizer. But I am getting errors while doing it. I searched various threads but still I am not able to fix this problem. Errors I got- 1) The following surfaces may intersect other surfaces in the model, Please mesh with a larger element size, use virtual topology or correct CAD geometry. 2) A mesh could not be generated using the current meshing options and settings. Hint: The problem geometry areas might have been highlighted. Switching to wireframe mode may make them more visible. I have used share topology function also. But still I am getting this errors. I am attaching the iges format. PSA3.zip |
March 15, 2016, 04:20 |
Nader Khattabi
Rep Power: 10 |
try to chose a larger size for the minimum size of elements and see what changes .
I tried to mesh the model using Ansys meshing but it doesn't work.I ran a topology using ICEM-CFD and it brought a lot of mistakes in the geometry probably you should go back to CAD and try to rebuild your model then import it to your meshing software as IGES or Parasolid file (x_t). |
March 15, 2016, 09:36 |
Kushal
Rep Power: 10 |
Thank you very much Nader for Quick reply.
As you said I went back to CAD model and made the geometry in a single huge part. Now I am not getting any error with a very fine mesh. |
March 15, 2016, 14:38 |
Nader Khattabi
Rep Power: 10 |
You're welcome anytime, glad that it works now
meshing, pressure swirl atomizer, share topology |
Airfoil simulation - Divergence of the results - Mesh or geometry problem ? | Pol.P | FLUENT | 9 | March 7, 2022 17:21 |
[ANSYS Meshing] Meshing problem in a constricted geometry | kozden | ANSYS Meshing & Geometry | 0 | December 18, 2013 03:39 |
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 04:53 |
Problem meshing turb. blade tip clearance geometry | Balu | FLUENT | 0 | June 7, 2008 21:10 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
