[ICEM] problems with 90 elbow and make sure y+<1
Old   March 31, 2016, 21:41
Default problems with 90 elbow and make sure y+<1
志新高(Zhixin Gao)
zhixin is on a distinguished road
I use ICEM to get structure hexa mesh. Here is how I block the elbow.(due to y+<1, the first layer is less than 0.00085mm)
But when I set nodes number either more than 33 or less than 33 in the Circumferential direction, there will exist negative volume
By the way, the contours of y+ is also strange(this time I use more block at the elbow part)
this is the cell mass fraction of first layer, and is seems to be wrong.
so anyone can help me?
Thanks.
zhixin is offline   Reply With Quote
[ICEM] Pipe 90 elbow joint meshing issue sihaqqi ANSYS Meshing & Geometry 25 April 17, 2015 04:59
[ICEM] Blocking an elbow (block not conforming to geometry) llrr12 ANSYS Meshing & Geometry 0 January 22, 2015 22:06
[DesignModeler] Parametric elbow pipe thaenan ANSYS Meshing & Geometry 0 May 18, 2012 16:26
Simple pipe layout - 2 pipe joined by a 90 degree elbow GamFlu ANSYS Meshing & Geometry 1 April 26, 2011 07:56
Creating inflation layers for elbow with airfoil ! Aplus CFX 1 March 13, 2006 22:22
