Negative elements
Old   April 26, 2016, 07:58
Default Negative elements
vijaykamesh
vijaykamesh is on a distinguished road
I'm meshing a tidal turbine in Icem with two domain. I done with the meshing and i checked the mesh quality by det 2x2x2. It showing a negative values, i.e. bad elements (few) around the hub part. I checked the elements there but it looks fine. The both sides of the hub mesh is almost similar. The edge spacing and nodes are almost similar. The other side of the hub is not having any bad elements like this. I dont know how to fix it. Please see the pics. Third picture is mesh on the other side of the hub which dont have any bad elements.
vijaykamesh is offline   Reply With Quote
Old   April 27, 2016, 03:06
alirezame is on a distinguished road
have you checked the orientation of the surfaces? x=i, y=j and z=k
I have not worked with ICEM but in all of the meshing codes there should be possible to define or change the orientation of surfaces or zones.
alirezame is offline   Reply With Quote
Old   April 27, 2016, 22:54
david
davidwilcox is on a distinguished road
i encountered this lots of time. The way i solved it is to first highlight the areas of negative determinants. Then what i normally do is move the points connecting the edges ( not curves!) around that area. I said edges because i'm assuming you are doing the blocking method. this is very common if you have twists in the geometry.
davidwilcox is offline   Reply With Quote
Old   April 28, 2016, 07:54
vijaykamesh
Yeah, I'm doing structure mesh. I understand that you meant vertices. I tried already by moving vertices, changing nodes and spacing but nothing improves here. The hub part is little complex in geometry and I'm using low y+ values so first cell distance is 6.7e-6 m. The bad elements also forming for first two layers from the surface. if i increase the first cell distance the number of bad elements(negative values) are reduced but not completely removed. I zoomed the elements and i see there is overlapping of cells (not sure). If its overlapping of cells means how it can be rectified.
bad elements.
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
