April 23, 2014, 02:15 |
import icem mesh into ANSYS APDL
fariba k.
Rep Power: 12 |
Hi everybody. I did my meshing using ICEM, I want to import it to ANSYS apdl. Now I have my mesh in .msh and .uns formats. Is there any way to convert it to a suitable format for apdl?
May 4, 2014, 12:36 |
Gwenael H.
Rep Power: 20 |
Well you have several options to achieve what you want, I give you one that I use. If you're working with the WB then simply add a "FE modeler" and browse your .uns mesh that you've created with ICEM (you can select the mesh type, in your case .uns). Then simply link the FE modeler with ADPL and update it. |
May 8, 2014, 03:39 |
#3 | |
fariba k.
Rep Power: 12 |
May 8, 2014, 12:32 |
Gwenael H.
Rep Power: 20 |
You're welcome, glad it worked out.
January 15, 2015, 15:57 |
Can not select lines or area.
Abdullah Al Amin
Rep Power: 14 |
Hi Gweher,
I am preparing my mesh into ICEM, importing it into APDL according to your suggestion. It seems to load the mesh perfectly, but when I wanted to select areas/lines to apply boundary conditions, it says area/lines doesn't exists. Can you please let me know how can I make the mesh behave as it does when I run the analysis entirely from APDL? Best, Abdullah Graduate Research Assistant Case Western Reserve University |
May 21, 2016, 02:31 |
#6 | |
Rep Power: 10 |
Have you found a way to solve your problem? Could you share with me about that? Yours, Alam |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] 2D Mesh from ICEM to ANSYS FLUENT | TomM | ANSYS Meshing & Geometry | 1 | May 8, 2013 14:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
ANSYS ICEM CFD Mesh to Gambit | Simon Bergström | FLUENT | 0 | January 19, 2007 11:53 |
How to import mesh from Ansys? | Achilleas | FLUENT | 6 | August 9, 2005 10:59 |
