[GAMBIT] Viewing the volume of a group/cell zone (Gambit - Fluent) |
May 22, 2016, 07:41 |
Rob Vervoort
Rep Power: 10 |
I created a grid in Gambit consisting of many different volumes. The grid is subsequently divided into several groups which are translated to cell zones when loading the mesh in Fluent. For some calculations, the total volume (in cubic meters) of all the volumes in the group is required. Is there a way to display the total volume of all the volumes in a group or cell zone in Gambit or Fluent? kind regards, Rob |
May 23, 2016, 01:30 |
Maxime Perelli
Rep Power: 41 |
you cannot directly get the total volume Summarize groups doesn't do the job Summarize Volumes do the job if you select all your volumes (use filter / group) But then you have to do the math, because gambit will give you all the volume. I think a script will the solution
In memory of my friend Hervé: CFD engineer & freerider |
volume cell zone, volume group |
[GAMBIT] periodic faces not matching | Aadhavan | ANSYS Meshing & Geometry | 6 | August 31, 2013 11:25 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Facing Few Problems in Fluent and Gambit | Ravi Duggirala | FLUENT | 5 | March 11, 2006 03:13 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
