[DesignModeler] Create baffles
Old   May 10, 2016, 11:36
Default Create baffles
Stu
fluidstu is on a distinguished road
In DesignModeller, I have a cylindrical tank which I have specified as a fluid body.
I would like to create two baffles which come down from the ceiling of the tank. I would like to 'bore' two holes down through the top of the tank which would represent the baffles.
I have read in a separate post that creating a 'solid' region for each baffle is not optimal.
I have tried searching for a 'cut' tool or 'bore' tool but these terms return a host of unrelated things.
How do I create these baffles?
fluidstu is offline   Reply With Quote
Old   May 29, 2016, 23:47
ali
eng_norouzi is on a distinguished road
split your body at location you want to put the baffle,
then make your baffle surface by using imprint face tool,
create a multibody,
in the end use share topology,
then you have a baffle with zero thickness
eng_norouzi is offline   Reply With Quote
baffles, mixing tank
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? keepfit OpenFOAM 4 February 19, 2017 14:40
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
about modelling of baffles in Flow-3D tecmia FLOW-3D 0 September 24, 2012 09:27
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
