[ANSYS Meshing] Interface node number and memory allocation problem |
June 22, 2016, 01:22 |
Jinwhan Ryuk
Rep Power: 13 |
Is there anyone who know memory allocation for interface node number? There are many long and thin pipe in the cylindrical tank. Hot gas flow in the pipe and water flows between tubes in the tank oppositely. So there are many interface between tube surface and tank. Is there any tip for setting memory allocation in CFX due to interface nodes number? I thought 128gigabyte memory was enough for any problem but I was wrong.
June 22, 2016, 04:08 |
#2 | |
June 22, 2016, 04:41 |
Jinwhan Ryuk
Rep Power: 13 |
Thank you very much Far. I'll check it and try again. Where do you and can you check 'the aspect ratio at interface?' I can't find it. Mesh statics shows only overall aspect ratio only.
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 08:44 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
