[ANSYS Meshing] 3-D meshing with multiple parts
Old   June 26, 2016, 16:44
Default 3-D meshing with multiple parts
Sajjan Pokhrel
pokhrel is on a distinguished road
Hello Everyone!!
I am trying to mesh a turbine in Fluent.
I have three different parts namely stationary domain, rotating domain and blades. Out of which two parts are to be meshed and one part ( blades ) need not. Combine images and separate images are attaches along with.
I tried to mesh stationary and rotating fluid domain separately. To mesh stationary part, I suppressed rotating fluid domain and blades. And to mesh rotating fluid domain, I suppressed stationary fluid domain and blades. But when I unsuppress them all, it displays "update required" symbol beside MESH. Ans as I update the mesh, It does not gets updated, rather meshing runs for indefinite time (till I click stop button).
My queries are:
1) Is the approach that I am following leads to correct mesh ?
2) Is it impossible to mesh parts separately (suppressing) other parts and finally update a mesh?
P.S. I used patch independent method to mesh rotating fluid domain whereas I used sweep method to mesh stationary fluis domain.
Thank You.
Any help will be appreciated.
pokhrel is offline   Reply With Quote
[OpenFOAM.org] Install openFOAM 3.0.1 in Ubuntu 16.04 LTS from Deb packs Pier84 OpenFOAM Installation 4 June 18, 2016 16:22
[Other] Meshing of very small parts Gerrit OpenFOAM Meshing & Mesh Conversion 1 January 22, 2016 09:55
[GAMBIT] Meshing multiple 3D regions gascortado ANSYS Meshing & Geometry 2 February 7, 2011 12:12
Meshing support parallel multiple computers! Kevin Siemens 1 July 26, 2007 19:27
Meshing a volume having two parts IQTEDAR FLUENT 0 December 25, 2002 15:58
