[ANSYS Meshing] how to do with the deformed grid |
November 28, 2017, 21:17 |
Rep Power: 8 |
I construct the model by 3d-max.and then i import yhe model into workbench in the docunment format of stl. I intend to conduct a 2d plane strain test .There is something wrong with my model.Some extral lines apper when the model generated in the designmodeler.,which cause the bad mesh with the sharp angels. I wonder there is some way to improve the bad mashes by use workbench
November 29, 2017, 07:40 |
Gwenael H.
Rep Power: 20 |
Usually its not recommended to use .stl as an import format, especially for 2D analysis. You should go for a cad format (parasolid, .step, .iges) instead of a faceted data as you need to convert it in DM.
If you can only export a .stl you have 2 options. When importing a .stl you often end up with those splits in your geometry so you should either merge the separated faces using > tools > merge faces. Or I would extrude the 2D geometry in 3d-max and then take a slice plane in DM. Have fun |
December 4, 2017, 03:29 |
#3 | |
Rep Power: 8 |
Fluent LES model: grid requirement? | dinhanh | FLUENT | 1 | November 11, 2015 12:15 |
How to make grid for LES simulation | dinhanh | Main CFD Forum | 3 | November 11, 2015 02:37 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 13:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 08:32 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 22:26 |
