[DesignModeler] Connecting Points From Coordinates File(s)
Old   August 23, 2016, 09:35
Default Connecting Points From Coordinates File(s)
Harry Eggo
harry94 is on a distinguished road
Hi guys, just stumbled across this thread. Attempted to revive it but the issue is relevant to Design Modeler so felt it would be more suitable here. Apologies to mods if this isn't convention.
I'm trying to import a large number of points and need a way to connect them all together and bound them by the z axis. It is elevation data that I am trying to import.
I have processed it on MATLAB and applied what has been discussed earlier to keep it between -500 and 500 for the x and y axis. I can't import my data in one as it exceeds 10000 but I've split it into different files. I find that I can import the files easily when clicking Create - Point - Create Coordinates file but when trying to create a 3D Curve (Concept - 3D Curve), I return the error message that declares that it can't read the file.
I have also tried to close the curve too which hasn't help.
I believe that this may be due to the points possibly intersecting with themselves but that is necessary in regards to what I need to do. Does anyone have a method that would allow me to connect all these points together?
Attached an example file.
harry94 is offline   Reply With Quote
Old   August 23, 2016, 14:11
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
try to do it in pieces. Or use some cad package.
Far is offline   Reply With Quote
3d curve, coordinates from .txt, designmodeler, points
moving mesh bc to define the movement of the points through their coordinates ALU OpenFOAM Programming & Development 2 June 15, 2015 10:52
How to import text file contains points coordinates in Design modeler (ansys12) m5edr CFX 1 February 1, 2012 04:44
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
Mesh to points cells faces and boundaries files billy OpenFOAM Pre-Processing 19 April 18, 2006 15:38
