August 25, 2016, 03:16 |
decreasing y+
mehran mohammadi
Rep Power: 9 |
hi
i'm trying to meshing this geometry my mesh quality is good my y+ is about 60 but in section that multiphas is began is about 300 how can i Decrease it? my mesh size close to wall is 1mm and my vlosity in multiphase section is 2m/s , water come from nozzle and go out from diffuser and that above box is air. thanks |
August 25, 2016, 07:33 |
Harry Eggo
Rep Power: 10 |
Run the simulation with what you have and graph out the y+ values you obtain after convergence. Then you can use the solver to target specific values of y + (I think it comes under the modify menu in the top toolbar) and run the simulation again for ~800 iterations. Check your result and keep repeating and checking what sort of values you are getting.
August 30, 2016, 07:37 |
mehran mohammadi
Rep Power: 9 |
thak u for replying
Water level decreasing - interFoam | OEC | OpenFOAM Running, Solving & CFD | 0 | April 16, 2015 09:28 |
Buoyant flow in a sealed rotating cavity - heat flux decreasing | dpitz | FLUENT | 1 | October 29, 2014 09:14 |
Avoid creation of bad cells while decreasing distance between parts? | kg1913 | ANSYS | 0 | September 5, 2014 06:05 |
Nusselt number is decreasing when using nanofluid using single phase phase approach | kandoi | Fluent Multiphase | 1 | March 5, 2014 13:30 |
Too large temperature decreasing above sound speed | Roland R | CFX | 4 | December 7, 2009 17:17 |
