[Workbench] Flat plate solar collector drawing |
November 10, 2019, 07:35 |
Bence
Rep Power: 6 |
I would like to make a simulation of a flat plate solar collector but I think my geometry is not working well. Someone suggested me to not use interface just walls beetween the contact region, but I have no idea how to it right. When I use interface to the contact regions after appr. 120 iterations the energy grows up. When I'm not using interface the result is always 5000K temperature the top of the absorber plata. I just draw the absorber plate and tubes that you can see on the following picture: https://ibb.co/bHy4Qk3 https://1drv.ms/u/s!AocT2y5AsSDSjjOK...PUoTD?e=9aAmMa Also share my last attempt. Can someone explain how to do it right? Regards, Ben |
November 12, 2019, 12:56 |
Joshua
Rep Power: 11 |
Your links don't load properly for me. Can you attach photos directly to your reply instead?
November 12, 2019, 13:56 |
Bence
Rep Power: 6 |
That's the absorber plate and tubes. This drawing made in Autodesk inventor. Cant do the image with the direct method. You can try this link:
https://imgur.com/BmUlMcL Last edited by vki654; November 12, 2019 at 14:04. Reason: no pic |
November 12, 2019, 14:00 |
Bence
Rep Power: 6 |
For me these links are working, the insert does not work
solar collector |
[GAMBIT] Flat Plate Solar Collector | Heat Pipe | ANSYS Meshing & Geometry | 1 | November 7, 2017 06:20 |
Flat plate solar collection simulation | Baya | FLUENT | 1 | September 21, 2017 16:02 |
Using radiation model for simulation of flat plate solar collector | marjanbn | FLUENT | 1 | February 24, 2017 17:22 |
Flat Plate Boundary Layer Height | kennedy1992 | Fidelity CFD | 7 | February 24, 2016 04:45 |
Using radiation model for simulation of flat plate solar collector | marjanbn | FLUENT | 2 | March 15, 2015 10:27 |
