[DesignModeler] Boolean Not Available?... (Greyed Out) |
March 16, 2017, 18:00 |
Puya
I have uploaded a simple geometry HERE.
When I open this file in DesignModeler the Boolean operation (Create > Boolean) is greyed out and I am not able to select it. I was wondering if anyone could help me figure out why that is and how I can fix it. I am new to ANSYS so forgive me if this is a trivial question but I have googled this extensively and was not able to find any other example of a similar issue. Thank you for your help |
March 16, 2017, 21:04 |
Puya
I was able to figure this out after playing around with the software.
For anyone having the same issue, the way DesignModeler works is that by default it merges the different solids. To create a solid and not have it merged with the previous body you need to choose "add frozen" when creating the new volume. This allows for having two separate bodies that can be subject to Boolean operations. |
November 29, 2022, 12:44 |
Manish Dash
I've chosen "add frozen" to the surface that I've created but it won't select it as the tool body while subtracting.
ansys, boolean, designmodeler |
Fluent does not launch from workbench | NickyNac | FLUENT | 8 | April 13, 2018 09:42 |
FLUENT not running | CFDFRED | ANSYS | 5 | April 20, 2017 00:53 |
[DesignModeler] Before using boolean VS after using boolean ! | amin.z | ANSYS Meshing & Geometry | 0 | May 28, 2014 03:20 |
[ansys fluent] problems of running ANSYS 12.1 fluent module | mkwang2006 | FLUENT | 3 | September 30, 2013 10:59 |
Info message -> Fluent does not start | Jenson | FLUENT | 0 | December 22, 2011 17:21 |
