May 25, 2017, 14:03 |
boundary layer problems
hgggfh
Rep Power: 9 |
hey guys
im facing a problem in my boundary layer mesh around the my shape, its becoming in this way and i dont know why can any one help me >>>> 23-May-17 10-55-14 PM.png 23-May-17 10-55-49 PM.png |
May 25, 2017, 16:00 |
D. N. Venturi
Rep Power: 13 |
Hi, this is pretty simple to modify.
You just have to change the "Collision Avoidance". Try, for instance, changing from "Stair Stepping" to "Layer Compression". |
May 26, 2017, 02:02 |
hgggfh
Rep Power: 9 |
i did that he then gives me the following errors
concerning the 1st error he didnt say why its failed !! concerning the 2nd error i dont see a badness in my inflation meshing concerning the 3rd error i didnt understand it well 1.png 2.png 3.png and this is my inflation and sizing : 4.png |
May 26, 2017, 07:32 |
D. N. Venturi
Rep Power: 13 |
Well, I can't help you more than that. This errors do happen. To solve that you'll have to "play" with the meshing parameters (min and max sizes, angles, transition, pre or post inflation, ...)
May 27, 2017, 04:16 |
hgggfh
Rep Power: 9 |
ok no problem
thanks alot can anyone help me /?? |
May 29, 2017, 20:03 |
Rep Power: 14 |
check "problematic geometry" and post here
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
