June 14, 2017, 07:32 |
Edge meshing
Codemania34@yahoo.com
Rep Power: 9 |
When I select two side edges of a surface body why is it that only the first cells are divided into parts but not others? And why is it that the frequency of sub-cell become lesser when going inside?
Thank you. Last edited by cfd-eng; June 14, 2017 at 13:22. |
June 14, 2017, 19:34 |
Rep Power: 14 |
its because you have not given edge sizing for whole body length.
Select length edge and give sizing thr as well. depending on "bias type" you can change the type of mesh you need going from inner to outer or vice versa |
June 15, 2017, 02:39 |
Rep Power: 9 |
When I try to do it again I cannot do. When I select edge, and two sides without giving any sizing nothing changes. Would you explain the steps how I can do it again?
Thank you. |
June 16, 2017, 06:31 |
Rep Power: 12 |
Try to insert some sizing, and a change will come after you have found suitable parameters. Kapi's point of view was correct in my opinion.
[ICEM] ICEM CFD meshing lock edge mesh size | vickyiamlucky | ANSYS Meshing & Geometry | 1 | April 28, 2017 08:27 |
Meshing around sharp trailing edge in CFX | ttu004 | CFX | 1 | November 8, 2013 05:48 |
[DesignModeler] Importing Solid Edge ST4 Geometry into Ansys Fluent 13.0 for meshing | The Mighty Rearranger | ANSYS Meshing & Geometry | 0 | November 27, 2012 12:44 |
Meshing for 3D wing with tubercle on the leading edge in GAMBIT | nvtrieu | FLUENT | 0 | August 14, 2010 10:13 |
Meshing trailing edge of aerofoil | CC | FLUENT | 1 | December 10, 2008 03:49 |
