[DesignModeler] missing geometry warning in Ansys Design Modeler |
June 19, 2017, 16:24 |
dilaw meda
Rep Power: 8 |
hi, i created a nozzle in Ansys Design Modeler, then i export it in IGES file. when i opened a new project and imported the IGES files, warnings appears and some faces were was messing (see the figure). this is the warning message: " Warning: At least one of the imported/attached/converted bodies could not be validated. It is possible that subsequent modeling operations will fail.
Additional information: The following could not be validated: 1 Unknown Body Context: Feature Import4 " |
June 19, 2017, 22:30 |
its importing as several parts.
when you created it, did you make "part" of all the bodies? if not then you should, you can also boolean them if you want to treat them as 1 body. |
June 19, 2017, 22:33 |
dilaw meda
Rep Power: 8 |
No i did not make "part" i used "skin/loft" to connect the thred sketches ( cercle of inlet + cercle of middle + daisy shape) if you want i will put a screen shot, i still have the project of construction of the nozzle
June 20, 2017, 13:35 |
dilaw meda
Rep Power: 8 |
i made part but nothing changes
June 20, 2017, 19:11 |
yardena jodeck
Rep Power: 9 |
You can use add freeze in the extrude and skin options instead of add solid. Then select the objects and do " form new part "
Sent from my SM-G570M using CFD Online Forum mobile app |
June 20, 2017, 19:12 |
yardena jodeck
Rep Power: 9 |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[DesignModeler] How to write the script in the ansys design modeler? | deddy1973 | ANSYS Meshing & Geometry | 3 | October 4, 2013 05:08 |
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? | randomid | OpenFOAM Community Contributions | 1 | August 27, 2010 05:15 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
