[GAMBIT] meshing a circle touching the surface |
June 15, 2017, 07:07 |
Rep Power: 8 |
Hi
I want to mesh outside the circle touching a surface.It ca be understood as circle with tangential surface. |
June 16, 2017, 01:46 |
Maxime Perelli
Rep Power: 41 |
It will bring you high skewed cells, since tangential "part" will be assimilate as a cell with very small angle.
However you can fix the problem by splitting edges forming this sharp angle
In memory of my friend Hervé: CFD engineer & freerider |
June 19, 2017, 03:57 |
Rep Power: 8 |
Thanks for the reply mAx.
Highly skewed elements were found near the contact of the circle and the surface.I have tried to split the zone in different methods.I still find this highly skewed cells problem near the contact region in every method I tried. Can you suggest the correct method to split. |
June 19, 2017, 05:01 |
Maxime Perelli
Rep Power: 41 |
can you post a picture in the area where skewed elements are located
June 19, 2017, 06:07 |
Rep Power: 8 |
PFA the pics
June 19, 2017, 07:01 |
Maxime Perelli
Rep Power: 41 |
check the picture
June 19, 2017, 07:47 |
Rep Power: 8 |
Thanks for the immediate reply mAx.
If we delete those surfaces as indicated by you, are we not approximating the surface to be touching another surface instead of point touching a surface? Will that not matter if the bottom line (not the circle) is a heater surface? Is this approximation correct? |
June 19, 2017, 08:16 |
#8 | |
Maxime Perelli
Rep Power: 41 |
You have to wonder how many surface ratio did you supress by deleting those surfaces? I am not an termal expert
June 20, 2017, 04:37 |
#9 |
Rep Power: 8 |
Thank you mAx.
I will follow this and will check after the post processing. |
[snappyHexMesh] MRF meshing: not sure what I'm doing wrong | me3840 | OpenFOAM Meshing & Mesh Conversion | 0 | January 20, 2017 01:22 |
[snappyHexMesh] Bad meshing result on corrugated metal sheet | UebertreibeR | OpenFOAM Meshing & Mesh Conversion | 1 | August 19, 2016 04:55 |
[ICEM] Unstructure Meshing at the Wing Tip Surface from Imported Plot3D Structured Mesh | yona | ANSYS Meshing & Geometry | 8 | January 21, 2014 10:06 |
Shared surface between bodies for better meshing? | alxe | ANSYS Meshing & Geometry | 5 | August 18, 2011 11:52 |
Anisotropic surface meshing | fxzf | Main CFD Forum | 0 | March 7, 2011 05:21 |
