[ANSYS Meshing] i want to mesh tubes fluid of an exchanger (shell and tube)
Old   June 20, 2017, 23:36
Question i want to mesh tubes fluid of an exchanger (shell and tube)
ahmadreza
2440016489 is on a distinguished road
I want to mesh the tube side fluids of a shell and tube exchanger that it has 472 tubes with 32 mm diameter and about 3000 mm length.
this exchanger has some details that i can't use symmetry.
I'm using a HP computer with 16 cores cpu and 32 GB ram.
It's meshing process with this computer was run by multi zone and 10 mm element size setting but it's meshing after 3 days was not completed.
please help me about meshing method and settings for this mesh
2440016489 is offline   Reply With Quote
Old   June 21, 2017, 03:00
divergence is on a distinguished road
Test that your size settings are ok for the case by creating a mesh for just one tube. Moreover, you should probably mesh your volume in several smaller parts instead of just pushing the yellow lightning symbol.
If the mesh is not ready in three days, it is probably not going to look that nice. I would guess that the program is trying to create a mesh consisting of tens if not hundreds of millions individual cells, which is most likely a case of overbombing.
Multizone should do the job quite well but be vary about the choice between tetrahedral and hexahedral cells, which can both be created with the method.
divergence is offline   Reply With Quote
Old   June 21, 2017, 03:18
Lightbulb Thank you
ahmadreza
I will try this method
ansys meshing, mesh method, shell and tube exchanger, tube fluid
Regarding change of tube material of shell and tube heat exchanger kkj1234 FLUENT 0 October 16, 2016 22:39
Error in CFX Solution for Shell and Tube Heat Exchanger Shomaz ul Haq CFX 3 October 13, 2015 10:49
Analysis of shell and tube heat exchanger in Ansys Dena FLUENT 0 June 12, 2015 13:39
Shell and tube heat exchanger modeling hmasenger CFX 3 January 20, 2014 03:36
3D shell and tube heat exchanger Peter Jansen FLUENT 2 June 7, 2006 07:01
