[ICEM] Structured mesh of a complete Dornier 228 with its propellers
Like Tree3Likes
  • 2 Post By Far
  • 1 Post By Joachim
Old   May 3, 2012, 10:56
Default Structured mesh of a complete Dornier 228 with its propellers
Joachim
Joachim is on a distinguished road
Hello Everyone!
For my Master's thesis, I am currently trying to mesh a complete aircraft (Dornier 228) with its two propellers. I already have the CAD file, adapted for ICEM CFD (proper model, with curves, points,...).
The final goal of my thesis is to study the boundary layer at a specific location on the side of the aircraft. For this reason, I would like to build a structured, or at least hybrid mesh to properly capture this boundary layer.
My problem is: I don't have a lot of experience in CFD, and even if I have done all the ICEM tutorials, none of them deals with such a complex configuration. I have tried to create a blocking structure on my case, but it is causing me some troubles!
If you could recommend me a tutorial (I haven't found any), a book on the subject, or any advice, it would be extremely nice from you!
I can always do a fully unstructured mesh, with a prism layer at the wall and some density regions, but I would really like to know how to create a structured mesh!
Thank you very much for your help!
Joachim
Joachim is offline   Reply With Quote
Old   May 3, 2012, 15:00
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
You can download the blocking for similar cases from DAPW
http://aaac.larc.nasa.gov/tsab/cfdla...workshop4.html
http://aaac.larc.nasa.gov/tsab/cfdla...op4/grids.html
ftp://cmb24.larc.nasa.gov/outgoing/DPW4
ICEM files(direct link): ftp://cmb24.larc.nasa.gov/outgoing/D...tiblock_ANSYS/
Readme file:
ftp://cmb24.larc.nasa.gov/outgoing/D...SYS/README.txt
samchn and baislavipin like this.
Far is offline   Reply With Quote
Old   May 4, 2012, 12:47
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
If you plan to model the propellers, you should probably put the discs in early so you account for them in your blocking...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 9, 2012, 11:11
Joachim
Thank you for the links and advice!
Old   May 9, 2012, 12:31
Far
Sijal
By the way, these files were made (probably) by Simon
Old   May 9, 2012, 12:33
Joachim
Hehe, the world is small!
Far likes this.
Old   May 9, 2012, 14:19
Far
Sijal
I would be interested to see the final blocking for this case
Old   March 7, 2020, 07:14
Post Your Help needed for designing the aircraft
vijay
vijayganesh299@gmail.com is on a distinguished road
Right now I am in my 3rd Year Of Bachelors, and has been assigned to design and conduct analysis on dornier do 228. I have designed the fuselage and the wing but I am not able to design its tail wing and the propellers in catia . Can you please suggest the ways to make the elevator,rudder and propeller in catia
I also wanted to know about the different kinds of tests which can be conducted in ansys on the entire aircraft body??
vijayganesh299@gmail.com is offline   Reply With Quote
Old   May 10, 2021, 14:37
Samiul Hassan
Dodul is on a distinguished road
Hello again
The links above are not working for me.
Can anyone kindly provide me with some good links on meshing a propeller (steady mesh)?
Dodul is offline   Reply With Quote
structured mesh aircraft
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
