[TurboGrid] Coordinates Profile Turbogrid
Old   May 29, 2016, 15:54
Arrow Coordinates Profile Turbogrid
Marta
martalenz is on a distinguished road
Hello everybody!
I have a problem with Ansys Turbogrid.
I print the hub.curve and the shroud.curve properly, but i cannot understand which coordinate system i have to use to print the right profile.curve (cartesian, cylindrical...). I have a simple extruded compressor blade, and printing the simple cartesian coordinates of the profile I get the trailing edge non attached to the hub and the shroud.
Does someone know something about that?
martalenz is offline   Reply With Quote
Old   June 6, 2016, 13:44
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
what do you mean by printing the coordiantes?
Far is offline   Reply With Quote
Old   June 8, 2016, 16:26
Marta
I usually use Matlab to work on the airfoil profiles, and I was wondering how could I can elaborate the points and print them to txt files, so that Turbogrid can understand them.
For example, the Nasa Rotor 37's points, available in the Ansys's examples, are wrapped on non-plane surfaces, I think they are like cylinders.
Old   September 28, 2017, 02:07
Umer Sohail
MUSohail is on a distinguished road
Dear friend
I have just start working on rotor 37. I need its blade, hub and shroud curve files. Kindly share its files or geometry. i will be obliged. Thanks
MUSohail is offline   Reply With Quote
[UDF] Relative coordinates in logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 25 July 13, 2017 03:44
help : import impeller blade coordinates into turbogrid darKKnight Main CFD Forum 1 February 26, 2016 04:41
NACA profile coordinates melwyn rego Main CFD Forum 4 November 21, 2012 06:44
NACA profile coordinates ken87 FloEFD, FloWorks & FloTHERM 1 March 9, 2011 18:38
Unit Vector profile, cylindrical coordinates Felix CFX 3 February 6, 2009 07:34
