[ANSYS Meshing] inflation can't be activated?
Old   December 12, 2012, 09:06
Default inflation can't be activated?
Thomas Hoffmann
Thomashoffmann is on a distinguished road
Hi.
I'm having the problem that I can't activate inflation layers on my mesh, when I'm using sweep method. Anybody know how to get around this?
Thanks
Thomashoffmann is offline   Reply With Quote
Old   December 12, 2012, 09:23
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Right click the Method and selct "Inflate this method". Then you select the edge you want to inflate from, rather than the face which is normally what you do.
jrunsten is offline   Reply With Quote
Old   December 12, 2012, 09:44
Thomas Hoffmann
hmmm, I can't find what you refer to.. Can you go outline it more?
Thanks
Old   December 12, 2012, 09:58
Josef Runsten
It requires that you select the source face for sweeping first
Old   December 13, 2012, 10:08
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yea, sweeping is a little different than the other methods because it is really inflating on the perimeter of the source face and then sweeping...
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   November 6, 2017, 02:13
naman doshi
namandoshi is on a distinguished road
Originally Posted by Thomashoffmann View Post
Hi.
Thanks
i am also having same problem ur problem solve?
please help
namandoshi is offline   Reply With Quote
Total Thickness of Inflation Layer prikeyma CFX 5 August 28, 2020 03:22
[ANSYS Meshing] Inflation problem: Internal pipe flow with Turbulator Inserts Zaphod'sSecondHead ANSYS Meshing & Geometry 0 December 9, 2012 05:42
[ICEM] unwanted pre-mesh inflation around Ogrid macfly ANSYS Meshing & Geometry 7 September 25, 2012 09:41
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
Inflation Gab CFX 6 August 24, 2005 22:45
