[ICEM] O-grid around wing geometry
Like Tree1Likes
  • 1 Post By PSYMN
Old   September 28, 2009, 05:40
Default O-grid around wing geometry
Anorky is on a distinguished road
Hi everyone,
First of all thanks for reading my thread.
I am currently scripting a geometry construction and mesh generation in ICEM.
I want to construct a fully structured O-grid around a 3D wing geometry. An illustration of my geometry can be found in the attached figures.
Since I will mesh several types of airfoils and different "wing shapes" I want the blocking to be automatic. By different wing shapes I mean the cornering (arc or ellipse form) and dimensions.
Therefore I was planning to use the 2D surface blocking function to create the surface blocking and than extrude this 2D blocking to a 3D blocking.
I have tried and used this option for a more simple geometry and that worked fine.
However for this geometry I haven't had any succes obtaining a good blocking.
To create the fully structured (boundary layer) O-grid around the wing, I constructed a boundary layer geometry around the wing. The idea is to block the fluid region in between the outer, boundary layer geometry, and the inner wing geomerty.
Now I do the following steps:
1) open the geomerty, (wing geomerty, boundary layer geomerty; both are connected in the symmerty plane by surfaces, see the figures)
2) 2D surface blocking with following settings: Method: Mostly mapped; merge mapped blocks is off; 2D Free block mesh type is all quads; Selected surfaces: All
3)2D to 3D; O-grid option is off, simple fill is off.
What I don't understand is why ICEM creates 3 split block for the outer rear symmetry surface. Resulting in also 3 blocks for the "triangular region" between the trailing edge. I can imagine that this "triangular region might cause some problems. I included a figure that will make the above more clear.
Has anyone a suggestion how to achieve a clean blocking?
Another solution would be to start with a 3D bounding block and split this block manually and associate the relevant vertices and edges to the geometry. However this would be to complex to script for my problem since the number of cornering section, and corner shape (arc or ellipse,...) will change often. I think this solution wouldn't be that flexible to implement in my script code as the 2D surface blocking method would be.
I might have made a fundamental mistake from the beginning on but for this moment I am out of ideas for valid solutions so I hope someone can help me.
Any ideas or suggestions are welcome. If something is not clear, please don't hesitate to contact me!
Thanks in advance!!
kind regards
Anorky is offline   Reply With Quote
Old   October 12, 2009, 15:37
Default Try blocking it yourself...
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Yea, I would say the 2D blocking has not been ideal for this configuration, particularly with that lower block... It just sees the angles on that surface as too great to assume you want them mapped.
I would use scripting to record the interactive steps to generate an ideal 2D blocking.
I may be able to help with that if you want to send me what you have...
PSYMN is offline   Reply With Quote
Old   November 2, 2009, 04:55
Hi Psymn,
Thanks for replying!
Sorry for my late response, I haven't checked the forum for a while.
It seems I solved to problem by doing the blocking in 2 stages.
I create a 2D surface blocking for the front parts. The degenerate blocks near the trailing edge are made manually.
Then I merge both blockings yielding the final blocking.
This seems to work
Regards
Old   November 3, 2009, 17:42
Default fully scripted...
PSYMN's Avatar
Simon Pereira
Great, but just for the record, a fully scripted solution is possible. Let me know if want to try for that.
Simon
Old   November 5, 2009, 10:15
Hi Simon,
I have wrote a script that does the trick automated.
I am trying to write scripts for the complete mesh and geometry creation.
The geometry is created by use of several input parameters. Afterwards the whole blocking process and mesh generation are done by use of scripts.
In the end this should allow the whole mesh and geometry creation to be fully automated. This will be very usefull for me since I want to try several different configurations.
When I started the scripting process I hoped it to be easier than it is
I find it relative difficult to find a good scripting reference/ manual.
The replay function works fine altough a lot of unnecessary lines are recorded as well in my point of view. But it works fine to find the correct commands and arguments.
Do you have good reference material concerning the tcl/tk commands in icem despite the provided manual?
thanks for replying on my post!
Kind regards
Old   November 16, 2009, 20:22
Default Programmers Guide?
PSYMN's Avatar
Simon Pereira
Did you already find the programmers guide under "help"?
You could also go to "scriptics.com"
Old   November 17, 2009, 04:15
Hi Simon,
Indeed, I already know the programmers guide. The scriptics website I found a while ago but has been under reconstruction since than...
Thanks for the suggestions and if you would know other reference material it would be more than welcome
kind regards and thanks for replying on my posts!
Old   November 18, 2009, 06:26
Default 3D Iced Wing Meshing
Crazy CFD is on a distinguished road
Dear All of Friends!
I am currently trying to generate the 3D Iced swept wing mesh generating in Gridgen V 15.
First, I really thanks all of you for reading my wirtting.
I want to generate a multi-block Hybrid mesh or Fully Structured C-grid around the 3D Iced swept wing geometry.
Has anyone a suggestion how to creat a hybrid or sturctured multiblock grid around the iced wing geometry?
I hope someone can help me that problems.
Please give me any idea and advice!
welcome!!!
Thank !!
Crazy CFD
Crazy CFD is offline   Reply With Quote
Old   November 18, 2009, 10:16
Wink Sell crazy some place else
PSYMN's Avatar
Simon Pereira
What? Are you Crazy
This forum is mainly for ANSYS brand mesher (ICEM CFD Hexa, Gambit, TGrid, CFX Mesh, etc.), but there is another forum for Pointwise. You will probably find more Gridgen users there who can help you.
On the other hand, if you are interested in seeing how this would be done with ICEM CFD Hexa, I can help with that.
Old   November 21, 2009, 10:02
John Chawner
jchawner is on a distinguished road
Crazy:
As Simon says, join us crazy Pointwise people in the Main CFD Forum! Regardless, there are some very straight forward procedures for generating both hybrid and structured grids around wings and airfoils, iced or not. I would be interested in seeing the geometry first in order to get an idea of what we're talking about.
Simon: Thanks for pointing Crazy in our direction.
John Chawner / jrc@pointwise.com / www.pointwise.com
Blog: http://blog.pointwise.com/
on Twitter: @jchawner
jchawner is offline   Reply With Quote
Old   August 14, 2011, 03:10
LL
aweizazuji is on a distinguished road
Hi Simon, I just want to ask how you coud generate structure grid on the surface of the body(like in your attachment --the wing) and the generate unstructure grid in the field(like delaunary method)? thanks. I did this before , first i have structure mesh by blocking method, then change to mesh, but like in the symmetric surface ,when meshing it, even i use repect line element command, the nodes do not merge. thank you1
aweizazuji is offline   Reply With Quote
Old   August 17, 2011, 16:02
PSYMN's Avatar
Simon Pereira
For those models (the nacel, the fan blade and the F6 aircraft), I just used the "MultiZone" method.
It is really ICEM CFD Hexa, but with an "unstructured" block to cover the difficult area around everything. It handles the connectivity, sweeping, delaunay, etc. all on its own.
There should be a couple new tutorials coming out with 14.0 in a few months, and one of them is a propeller shaft similar to that fan example.
lenovosk likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
Old   August 17, 2011, 21:28
LL
Thank you Simon, I am looking forward.
Old   November 27, 2017, 12:42
gittagawa
gittagawa is on a distinguished road
Hello PSYMN,
I would be interested in learning how an iced-airfoil could be done using ICEM. Can you help me?
Thank you,
Git
gittagawa is offline   Reply With Quote
Old   November 27, 2017, 13:22
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Hi Git,
Well you've gone a long way to bring up this 6 year old thread . Unfortunately, as you can see on his profile, Simon our ICEM guru "retired" from CFD-online.
There are plenty of threats dealing with airfoil meshing and you can even find tutorials Simon made that are accessible here : https://www.youtube.com/watch?v=tYrbScUH9RE
Gweher is offline   Reply With Quote
Old   November 27, 2017, 13:43
gittagawa
Hello Gweher,
Thank you very much for your response. I will check out the link.
Git
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
Obtain Geometry Data from a Grid File in CFX 10.0 ARJUN CFX 2 August 17, 2006 07:20
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 08:24
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
