[TurboGrid] Meshinformation out of a.gtm file |
December 21, 2017, 07:51 |
Daniel
Rep Power: 9 |
Hello there,
I have a problem with getting important information of a mesh. I needed to change a blade profile and should compare it with the older version in an axial compressor. Now the problem is, that the older blade has been moved to the periodic boundarys. This has been done in TG with the function (under BladeSet) 'Bias of Blades towards High Periodics'. I only have the .curve Files and the final .gtm File for CFX. Is there any option I could check which value was chosen there? Thanks for any help !! |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 08:46 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
ParaView Compilation | jakaranda | OpenFOAM Installation | 3 | October 27, 2008 11:46 |
