[ICEM] Meshing a cylinder like geometry
Old   January 3, 2018, 07:55
Default Meshing a cylinder like geometry
Somashekhar Kulkarni
somas123 is on a distinguished road
I'm trying to mesh the cylinder like geometry shown in the images attached below. I've highlighted the areas where Wall spacing (Prism/hex layers) is required and also where mesh isn't required. I tried meshing it by creating a 2D swept block and then converting it to a 3D block. The 3D block was created around and above the inlet (in a straight line) only. Hence I was only able to create a surface mesh. The volume mesh was created only in the middle region, above the inlet, where the 3D block is present. How do I create a 3D block in the whole volume so that I can get a volume mesh? Or is it possible to create an unstructured mesh with prism elements at critical areas? Please help!
somas123 is offline   Reply With Quote
[Gmsh] Vertex numbering is dense KateEisenhower OpenFOAM Meshing & Mesh Conversion 7 August 3, 2015 10:49
[ANSYS Meshing] Meshing a Cylinder anuprdk ANSYS Meshing & Geometry 3 December 9, 2014 12:32
[ICEM] Block meshing strategy for a radiused cylinder Polarbear ANSYS Meshing & Geometry 2 June 18, 2014 14:24
[GAMBIT] Meshing 2 Dimensional square cylinder avsksan ANSYS Meshing & Geometry 1 February 11, 2013 02:41
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 04:53
