January 3, 2018, 07:55 |
Meshing a cylinder like geometry
Somashekhar Kulkarni
Rep Power: 8 |
I'm trying to mesh the cylinder like geometry shown in the images attached below. I've highlighted the areas where Wall spacing (Prism/hex layers) is required and also where mesh isn't required. I tried meshing it by creating a 2D swept block and then converting it to a 3D block. The 3D block was created around and above the inlet (in a straight line) only. Hence I was only able to create a surface mesh. The volume mesh was created only in the middle region, above the inlet, where the 3D block is present. How do I create a 3D block in the whole volume so that I can get a volume mesh? Or is it possible to create an unstructured mesh with prism elements at critical areas? Please help!
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Meshing a Cylinder | anuprdk | ANSYS Meshing & Geometry | 3 | December 9, 2014 12:32 |
[ICEM] Block meshing strategy for a radiused cylinder | Polarbear | ANSYS Meshing & Geometry | 2 | June 18, 2014 14:24 |
[GAMBIT] Meshing 2 Dimensional square cylinder | avsksan | ANSYS Meshing & Geometry | 1 | February 11, 2013 02:41 |
[Gmsh] Problem meshing an imported geometry | Alicia | OpenFOAM Meshing & Mesh Conversion | 0 | March 30, 2010 04:53 |
