[ICEM] Problem with exporting mesh after smoothing |
December 28, 2017, 09:39 |
I'm trying to mesh an airfoli in ICEM (2D, quads) and faced a problem with converting smoothed mesh to output mesh. The problem is that the output mesh is the same as the pre-mesh before smoothing (take a look at the pictures). When I convert pre-mesh to multiblock mesh everyhing is ok but then if I i want to write input files to fluent the problem appears. The same situation is when I'm trying to smooth multiblock mesh and then export it fluent. Could you tell me what I'm doing wrong? Output mesh -> https://ibb.co/jDpmHG Smoothed mesh -> https://ibb.co/mWwoWb Last edited by Wroobs; December 28, 2017 at 12:56. |
December 29, 2017, 05:41 |
#2 | |
Not the multiblock mesh option |
January 4, 2018, 16:12 |
Thanks for your replay, converting to unstructured mesh works but I still don't understand why it's necessary to use this option while the mesh is based on quads not triangles?
Additionally I'm wondering if there is any option that let me set mesh cells in boundary layer around the airfoil perpendicularly to its curvature through some distance? Is there any better option than o-grid mesh around the airfoils divided into many blocks with mesh shaped manually? |
[ICEM] Problem with using the Delaunay volume mesh method | manahara | ANSYS Meshing & Geometry | 12 | December 25, 2014 21:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[ICEM] Mesh Smoothing problem | star | ANSYS Meshing & Geometry | 2 | December 21, 2013 03:15 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
