[ICEM] Split blocks in ICEM
Like Tree2Likes
  • 1 Post By MangoNrFive
Old   February 25, 2018, 08:20
Default Split blocks in ICEM
AdelMahgoub is on a distinguished road
I am a beginner at ICEM and I tried to split the block as shown in the figure but it's not inclined the split is always vertical or horizontal so how could i split the block as shown in the figure for the blade to be contained by the split lines.
AdelMahgoub is offline   Reply With Quote
Old   February 25, 2018, 09:40
Philipp Wiedemer
MangoNrFive is on a distinguished road
That's not how you'd block such a geometry usually. I guess u want periodic boundary conditions on the sides, so your edges on each side need to be periodic as well. So the general approach would be like in this video: https://www.youtube.com/watch?v=7GLYQwCsc8A
Far likes this.
MangoNrFive is offline   Reply With Quote
Old   February 25, 2018, 11:12
I am using the same technique as in the video u referred to but, my problem is at block splitting into smaller blocks step (as in minute 6:25 in your video) i need a way to split inclined as in picture attached not just horizontal and vertical as in video
Old   February 25, 2018, 15:19
Philipp Wiedemer
I don't see the necessity to split it like that in this case, and it shouldn't work anyway. For a structured grid with Hex-Elements you need opposite edges with same node-count. In your picture there are 2 triangles in the top right and the bottom left which you just can't mesh.
The topologie shown in the video e. g. O-grid around the blade and H-grid for the rest should be fine, for the inlet at least. For the outlet it's a bit more difficult because of the angle of the blade. If you can it's probably good advice to move the outlet further in the top-right corner.
In this video a turbine blade with a similar geometry is being meshed with the same topologie:
https://www.youtube.com/watch?v=k943AOVKL3Q
Far likes this.
Old   February 26, 2018, 03:56
Thank u for this useful answer
blade, blocking, icem, mesh, split
[ICEM] Problem occur when i am trying to split block in ICEM CFD? premal ANSYS Meshing & Geometry 0 July 9, 2015 03:46
[ANSYS Meshing] ICEM structured grid: trying to maintain 1:1:1 blocks BahaZero ANSYS Meshing & Geometry 2 March 28, 2013 12:17
[ICEM] Union of blocks in ICEM TallesC ANSYS Meshing & Geometry 4 February 5, 2013 10:34
how to split hex mesh in icem with desired height? adam2008 ANSYS Meshing & Geometry 3 August 27, 2009 14:59
Who know how to use the split edge in icem cfd? carnivore Main CFD Forum 2 December 16, 2004 23:32
