[DesignModeler] Unable to generate an enclosure around simplified automobile
Old   March 12, 2018, 12:22
Unhappy Unable to generate an enclosure around simplified automobile
Sri Harsha Maddila
harsha2398 is on a distinguished road
A non-manifold error is showing up whenever I try and use 2 symmetry planes to generate an enclosure around my car saying it cannot because of non-manifold bodies. I don't understand what I should do to resolve it, can someone tell me what it is I should do?
Here's the geometry of the file and relevant screenshots:
https://1drv.ms/u/s!As6k8_h0tQpljp0yxFAy57fcW3RxwA
I use the STEP file for Ansys Workbench 18.2. Please suggest what it is that I should do!
My symetry planes are ZX plane and YX plane, but it throws up the error when I mention the ZX plane! And are there any other errors in the geometry that can affect the simulations later?
harsha2398 is offline   Reply With Quote
Old   March 12, 2018, 17:10
Default non-manifold
Nam
Gnak is on a distinguished road
I had the same problem before and the solution is to flatten the tire and create an extrusion underneath the wheels. It makes sense to do this since in real life your tire will flatten a bit on the ground making a plane as a result.
when you create the cut make sure to have some sort of extrusion underneath so you can avoid having a "cusp" around the wheels. It will make your life easier later on.
hope this helps
Gnak is offline   Reply With Quote
Old   March 13, 2018, 05:21
Sri Harsha Maddila
Attachment 62000
hope this helps
Thank you so much! It works!
Old   March 13, 2018, 16:22
Sri Harsha Maddila
I have a new problem, the enclosure after Boolean subtraction creates two square holes at the bottom where the tires are flattened and although meshing is successful, I'm unable to close them up by meshing and an stairstep warning is also showing up. How do I fix it? Suggestions mentioned increase maximum angle to 180 degrees but it didn't work. Images in link!
https://1drv.ms/f/s!As6k8_h0tQpljp037_fjr9ZvIwbRAQ
[ANSYS Meshing] Non-manifold error encountered while trying to generate enclosure PrinceTan ANSYS Meshing & Geometry 1 January 21, 2014 00:36
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 11:03
Unable to generate surface mesh for a coil pitisrisuk Main CFD Forum 1 December 2, 2011 15:43
[ANSYS Meshing] Unable to generate surface mesh for a coil pitisrisuk ANSYS Meshing & Geometry 0 December 2, 2011 11:51
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 15:45
