[Workbench] Melting of Phase Change Material (PCM) |
April 29, 2018, 12:55 |
Ariful Hassan Torin
I want to do this simulation given in the Picture. The simulation runs without any error. But problem is, pcm is not melting and no heat is transferring to pcm from the Heat Source. This can be visible in the result graphs.
My concern is regarded to geometry. First, I draw a rectangle and then draw to lines inside it. Used the option "Create Surface From Sketch". In the following steps, meshing,name selection and boundary conditions were implemented accordingly.No error message was shown. . So,can anyone point out how to draw the geometry properly to transfer heat from the source ??? |
Adding material to CFX material library | marlon | CFX | 2 | October 16, 2016 09:33 |
Material change during phase transformation (FePO4 > LiFePO4) concentration distribut | kimsw0103 | CFX | 0 | January 15, 2016 22:05 |
simulation of phase change material melting | rosol | FLUENT | 4 | December 8, 2015 07:56 |
Thermal Phase Change model | Niru | CFX | 0 | February 21, 2013 13:13 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 23, 2001 23:16 |
