[ANSYS Meshing] Unable to select multiple Faces Ansys 2021
Old   January 4, 2022, 10:05
Default Unable to select multiple Faces Ansys 2021
James_mCFD is on a distinguished road
I am trying to mesh a 3D object in Ansys 2021 which is long and thin so to expose and select all necessary faces I have to use the pan and rotate functions. The issue is that after reorientation of my model, when I click the select faces function the previously selected faces are deselected.
When using Ansys 2018 at work I do not have this issue; I am able to pan, rotate and select multiple faces without the previously selected faces becoming deselected. Is there a setting I need to turn on so that the faces I select remain if I click away from the select faces function?
I have also accidentally removed the quick access ribbon that contained the pan, rotate, zoom face select etc functions. How do I get this back?
James_mCFD is offline   Reply With Quote
Old   January 5, 2022, 04:52
siw
Stuart
siw will become famous soon enough
Do you have the Smart Select button active? This is a new feature and I find it can be a nuisance, I does not allow selecting items behind other items. If you only want to select all the faces then change to the Face Select, RMB in the graphics window and choose Select All.
siw is offline   Reply With Quote
Old   January 5, 2022, 06:07
Hi siw. Thank you for your response.
The smart select was not active, I activated it to see if it sorted the issue; it didn't!
The solution is to not click the select faces function after panning and/or rotating the geometry; instead click the single select function again. This automatically reselects the select faces function without deselecting the previously selected faces.
Easy fix when you know, but when used to Ansys 2018 where it works slightly differently it becomes less intuitive!
deselected, panning, rotation, select faces
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
[snappyHexMesh] layer not added Rasmusiwersen OpenFOAM Meshing & Mesh Conversion 1 January 2, 2020 09:43
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 14:49
SigFpe when running ANY application in parallel Pj. OpenFOAM Running, Solving & CFD 3 April 23, 2015 14:53
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
