[DesignModeler] Need some help for CFD Modeling |
August 8, 2018, 18:29 |
Saha
Rep Power: 7 |
Using Ansys Fluent.
The two pipes in attached geometry figure are intersecting. I want the fluid flow in the main (larger) pipe, to get obstructed by the smaller pipe where it is protruding into it. The flow from smaller pipe should mix with the main fluid flow from the sides and bottom of larger pipe. I tried running a simulation, and not getting the desired contour/vectors. Basically, mixing is not proper, and I suspect it's due to the geometry. Please help! Below are images for what I need: https://ibb.co/b5rXo9 https://ibb.co/ndMnMU PS: I tried Boolean, but I think I did something wrong in its application. Really looking for some guidance here for the geometry! Thank You! |
ansys, cfd, fluent, geometry, mesh |
What kind of turbulence modeling is applied for my problem in Fluent? | Roh | FLUENT | 1 | February 28, 2018 17:08 |
side jet modeling for a missile: 1st order or 2nd order scheme | AmirBaqa1987 | ANSYS | 1 | March 19, 2014 04:39 |
May Focus Area: Turbulence Modeling | Jonas Larsson | CFD-Wiki | 0 | May 2, 2006 11:48 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
