[ANSYS Meshing] Meshing cyclone separator
Like Tree1Likes
  • 1 Post By Rajaero
Old   August 1, 2018, 07:07
Default Meshing cyclone separator
RRT
Choose Country Then State
RRT is on a distinguished road
Hi .
I have a problem while up dating the mesh .Can some one help !
This message appears :
'Échec de la mise à jour du composant Maillage dans Maillage. Erreur lors de la mise à jour de la cellule Maillage dans le système Maillage. Consultez les messages dans l'éditeur Maillage pour plus de détails'
RRT is offline   Reply With Quote
Old   August 2, 2018, 04:32
Taiwan,new north city
Rajaero is on a distinguished road
Can you post a error message in English?
Thanks...
Rajaero is offline   Reply With Quote
Old   August 2, 2018, 05:13
Default Meshing a cyclone separator
RRT
Originally Posted by Rajaero View Post
Thanks...
This is the error message in English:
'Failed to update the Mesh component in Mesh. Error updating the mesh cell in the mesh system. Check the messages in the Mesh editor for more details'
Old   August 2, 2018, 20:28
you need to open the error message in mesh tree. its a warning its not actual error message. you can open the error message in mesh tree at bottom.
Please post the actual error message.
Thanks...
Old   August 4, 2018, 09:08
RRT
Thanks...
'Failed to break into MultiZone blocks. Right-click on this message to access the "Show problematic geometry" function and try a different approach to mesh these bodies.
You can not generate a mesh based on the current mesh options and settings.'
Old   August 6, 2018, 00:03
i got your problem now. please follow the steps below,
1. you need to change your mesh method
2. multi zone mesh is not appropriate for some parts of your model
3. Try to use other mesh type or reduce your element size.
Thanks...
RRT likes this.
Old   September 28, 2018, 07:27
Default creditcardlogin
creditcardlogin
creditcardlogin is on a distinguished road
creditcardlogin: A mainstream physical retail goal, and also a go-to goal for on the web and application customers — works 1,100 retail chains in 49 states
creditcardlogin is offline   Reply With Quote
Ideas about Gas - Solid Cyclone Separator Simulations ardismo FLUENT 4 April 6, 2016 08:04
Ideas about Gas - Solid Cyclone Separator Simulations ardismo Main CFD Forum 0 January 11, 2016 10:46
CFD-DEM in cyclone separator Deepakjsd FLUENT 0 February 22, 2012 07:52
how to set BC of cyclone separator outlet Lcw FLUENT 5 February 22, 2012 01:40
water-oil cyclone separator Nico FLUENT 1 May 24, 2005 14:58
